NorthTown2022
So, It appears I am having inconsistent voltages being reported by the BMS. It's a JBD AP20S003S contactor model.
The voltages at rest, measured at the cells measure exactly the same at the BMS connector to .000v while the BMS reads 6 to 11mv above the DVOM. This was measured at 98% SOC (which is not entirely accurate).
Discharging at 56A 95% SOC and BMS reporting 3.28 - 3.29v the BMS reads -1mv to 6mv above DVOM.
Discharging at 56A 90.8% SOC and BMS reporting 3.28 - 3.29v the BMS reads -2mv to 5mv above DVOM.
Charging at 25A 91% SOC and BMS reporting 3.36 - 3.36v the BMS reads 9mv to 12mv above DVOM.
Charging at 49A 92.9% SOC and BMS reporting 3.38 - 3.39v the BMS reads 9mv to 12mv above DVOM.
Charging at 60A 94.8% SOC and BMS reporting 3.37 - 3.38v the BMS reads 10mv to 17mv above DVOM.
Charging at 25A 96% SOC and BMS reporting 3.37 - 3.38v the BMS reads 8mv to 12mv above DVOM.
@John Frum
@John Frum
