My configuration has two 8.0 kW Deye Hybrid in parallel. They are new and have been operating for about 3 weeks. On one occasion i noticed that the SOC was changed (reduced downwards) during the night which required additional charging to recover the SOC the following day. They then operated for some days with the SOC following quite closely the actual charge/discharge as a % of the total capacity. Also the battery voltages looked about correct. I have Lead acid batteries. The system charges the batteries during the day and discharges once the sun goes down until an SOC of 55% is reached when the load is supplied from the grid. The batteries then charge up the next day and can reach about 100% with good sun. The problem is that last night at some time the inverters changed the SOC from 55% to 0%. Now today it is charging back again and has reached about 55% with the % matching closely the actual charge volume. The problem is that the batteries are now about 100% charged because the voltage has reached the absorption value of about 57.5 V. I have checked that the battery capacity is set correctly and the batteries are new valve regulated batteries. The system would have been working correctly if it had not reset the SOC to 0%. overnight which was a huge change. Has anyone had this problem. There does not appear to be any way to adjust the SOC which I guess is internally calculated.
