Here's a fun article:
https://www.google.com/url?sa=t&sou...FjAUegQIAhAB&usg=AOvVaw094jKAx06i96hYzK8-ojqt
2.4. Battery Degradation and Second Life Application
Lithium batteries for EVs are subject to two mechanisms that shorten life-time and deteriorate
performance, namely cycling capacity loss and calendar capacity loss. The former depends on the
number of battery charging/discharging cycles, while the latter depends on the state of charge, aging
time, and expose of the battery to high temperatures. Specifically, cycling capacity loss is typically
attributed to the formation of solid electrolyte interphase (SEI) layer, structural changes in the electrodes
and loss of lithium during battery charging/discharging. Calendar capacity loss is attributed to battery
self-discharge and side reactions that occur during the energy storage period [29].
It is estimated that LFP batteries can support at least 2000–2500 cycles in electro-mobility
applications, for example, daily use of a charge and discharge cycle for seven years, until the remaining
capacity reduces to 80% of the initial battery capacity. This allows its use for another 1000–2000 cycles
until the capacity reduces to 60% of the initial capacity. When this occurs, the aging process of the
battery has advanced to point that the voltage drop does not allow further use of the battery [30].
After the end of the useful life of a battery for electro-mobility purposes, typical applications include
its use as energy storage unit in smartgrids or uninterruptible power supply. The main characteristic
of these applications is the lower stress that the battery cells suffer, enhancing thus the durability of the
battery pack. In the context of this work, the primary use phase considers a 24 kWh LFP battery with
efficiency of 80% used for 2500 days in an EV, while the second life application considers the case of
using an LFP battery as an energy storage unit in a smart building for 1500 days (or equivalently, four
years), taking into account the average home consumption in Spain in 2010. In the scenarios that refer
to the use of the same battery in the primary and secondary application, it is further assumed that the
efficiency drops from 80% to 75% due to the aging of the battery.
