Dave911
I have a 90's era 17 cu ft upright freezer. I have replaced some of the controls over the years. The freezer just keeps running. It's been powered since about 1990.
So about 35 years. The compressor and fans are original and still work well. It's a very simple unit. No electronics of any kind.
The freezer isn't nearly as efficient as a newer model.
This old freezer likely uses about 1700 KWHR per year / 4.7 kwhr per day / $0.82 per day at my current power cost. (This via monitoring it with a Kill-a-watt device)
New freezers are in the 500 KWHR per year range / 1.37 kwhr per day / $0.24 per day
A new freezer, the same size, costs about $850
If I was to stay on the grid entirely, a new freezer would pay for itself in about 4 years.
I believe my entire solar system will pay for itself in 4-5 years (it's in progress).
So the payback for solar is about the same as the payback for replacing the freezer.
However, the newer freezers seem to have a much shorter life. 8-10 years maybe?
So the question is:
If I have sufficient solar capacity to cover most of my needs, do I care much about less efficient appliances?
I will be using the grid for backup power when the sun doesn't shine and for some heavy shop loads that I don't want to deal with (welders, big compressor, etc)
If I take the $850 I was planning on spending on the new Freezer, and instead spend it on more solar capacity/battery, etc, I feel like I will be further ahead.
What do you think?
So the question is:
What do you think?
