Inexpensive 120a 480v PV input charge controller
CommandoJoe
IFLA Evangelist
New Mexico
Here's another relatively inexpensive high current, high PV input charge controller. It will also handle battery voltages up to 96v.
There's also a 230v PV model for $100 less if you don't need the 480v PV
(Affiliate links)
I purchased this a couple months ago and it has been working without issue. I wanted to make sure it didn't have any issues before sharing with the forum here.
It appears to the same design/mfg as the SUYEEGO that I and several others on the forum purchased earlier this year.
(Search the forum for Suyeego and you'll get a bunch of results.)
It uses the same screen, options, and wifi app.
The only difference is my Suyeego will go up to 192v battery and this one says it only does 96v. BUT the app on this one does have the ability to change the voltage to 192, and model designation in the app is the same as my Suyeego - "M-120192". So maybe it will handle 192v as well, but I haven't tried yet. Either way, these high battery voltages are not a common use case for most people, so it likely won't matter to most.
I have seen max charging current (120a) earlier this summer.
I had initially bought this because I thought my Suyeego had a problem since it would only charge at 700w, even though I had 5000w of panels hooked up. This one showed the same issue. Turns out I had a bad crimp on a battery connection that was limiting charge current. Once I fixed that, this one and the Suyeego work fine.
I had purchased my Suyeego directly from Alibaba for about $225 before tariffs, but I know a lot of people are leery about Ali, so here's an alternative to buy the same thing on Amazon for only a little more - or maybe the same or less once the new tariffs are factored in.
Ali link for the other one I bought:
If anyone has any questions, feel free to ask.
I bought a 48v Y&H 6.2kw 230v AIO (on aliexpress) for $300. 450v pv max, 120a max charge from pv, and it is an inverter/charger too. I got it as I saw that as a better deal in my 48v situation. The voltage flexibility of this one is nice though. Vevor has a similar inverter that I got for $258 with online discount code.
Yeah, the AIOs are coming down in price, but 120v models seems to be a bit more than the 230v ones. The variable voltage is what drew me to the Suyeego initially as I was running a 36v system.
Do you happen to know what is the MINIMUM PV voltage is for the 230V and 480V models? If you ran say a 96V battery, would the PV voltage need to be somewhat higher than battery voltage?
Asking as the area I could mount a bigger PV string rolls in and out of partial shade through the day, so wondering if this could find MPP with a number of the panels shaded/bypassed, and with how many panels....
Spec says 60v for the 480v model, but you will need to be higher than battery voltage as well, I just don't know how much. I've seen other charge controllers that only need +2v or +5v above battery. But with such a high allowed PV input voltage, no need to run that close...
The ones that I mentioned were for 48v systems. I know there are 24v versions (with half the power rating). There may be versions for 96v if you search on ali-express.
The ones I linked are not fixed to a particular voltage and can go from 12v to 96/192v.
I did acknowledge that feature.
