Infini LV WP 6048
Troady
Hi guys, i am looking at a new inverter in the market, the Infini LV WP 6048. It`s made by Voltronic, same guys who made the MPP and Growatt.
So far they were having the LV 6048 (not waterproof) and the LVX 6048, i have seen the LVX WP 6048 announced to come soon, but the LVX do have a idle consumption of 135 watt/hr, way too much for my like, the LV 6048 WP seems to be more frugal in this aspect. One other thing that make me think about it, is the warranty and after sales service. Dealer says that they cover it for 45 days, after that Voltronic take charge for 5 years support and parts. Voltronic is in Taiwan, if something goes south, go figure.
What do you guys think?, this inverter being IP65 is perfect for my needs, just i am worry about after sales service.
They are asking $1900 + shipping for it.
MODEL InfiniSolar WP LV 6KW
Phase 120/240V Split phase, 120V Single phase, 120V/208V Split phase
Maximum PV Input Power 7500W
Rated Output Power 6000VA/6000W
Maximum Charging Power 6000W
GRID-TIE OPERATION
PV INPUT (DC)
Maximum DC Voltage 600 VDC
Start-up Voltage / Initial Feeding Voltage 120VDC / 160 VDC
MPP Voltage Range 120 VDC ~ 550 VDC
Number of MPP Trackers / Maximum Input Current 2 / 15A
GRID OUTPUT (AC)
Nominal Output Voltage 110 VAC (P-N) / 220 VAC (P-P)
Output Voltage Range 91.5 - 132 VAC (P-N)/ 183 - 264 VAC (P-P)
Nominal Output Current 27.3 A per phase
Power Factor 0.9 lag to 0.9 lead
EFFICIENCY
Maximum Conversion Efficiency (DC/AC) 96%
OFF-GRID OPERATION
AC INPUT
AC Start-up Voltage / Auto Restart Voltage 80 VAC (P-N), 160 VAC (P-P) / 85 VAC (P-N), 140 VAC (P-P)
Acceptable Input Voltage Range 85 - 140 VAC (P-N)/ 170 - 280 VAC (P-P)
Frequency Range 50 Hz/60 Hz (Auto sensing)
Maximum AC Input Current 30 A per phase
PV INPUT (DC)
BATTERY MODE OUTPUT (AC)
Output Waveform Pure sine wave
Efficiency (DC to AC) 91%
HYBRID OPERATION
PV INPUT (DC)
GRID OUTPUT (AC)
AC INPUT
BATTERY & CHARGER
Nominal DC Voltage 42-62 VDC
Maximum Solar Charging Current 120 A
Maximum AC Charging Current 120 A
Maximum Charging Current 120 A
GENERAL
PHYSICAL
Dimension, D x W x H (mm) 200 x 450 x 593
Net Weight (kgs) 25
INTERACE
Parallel Function Yes, 9 units
Communication Port RS-232, RS-485, USB, dry contact and Wi-Fi
ENVIRONMENT
Protection Degree IP 65
Operating Temperature -25°C to 60°C (>45°C derating)
BerSF
I really like this inverter but having problems. Trouble with firmware upgrade - I believe it’s the FTDI cable, will have to try another.
Also when you are upgrading the firmware you have to turn off the output power in this machine is extremely finicky about shutting off the load I don’t know what the problem is the manuals very clear about pressing escape button and holding it down but it just won’t shut off sometimes it does but the most of the time it does not. Hard to tell if there is communication between the inverter and the battery no errors and also no recognition that’s actually working or connected. Software provider by the vendor is garbage.
BerSF
