Hello,
I am in the processing of purchasing 5 x 15A fuses of the fuse holder type. I have come across two types: A) What looks like a typical fuse. B) Diodes. On the outside, they appear the same. However, the diode based ones are much cheaper. Are these equivalent?
Here is the original/conventional fuse type:
In the assembly diagram, you can see the fuse.
Here is the diode type:
Notice the one on Amazon is indicated 5 fuses for only $17.49! The first item above is $12.99 per fuse. That's a huge price difference if I need to purchase 5.
Are these equivalent in function? Would the diode offer the same protection as a fuse?
Thank you.
Ali
Amazon.com : RICH SOLAR 10A Waterproof in-Line Fuse Holder w/Fuse Solar Panel Photovoltaic Connector 10 Amp : Garden & Outdoor
www.amazon.com
INLINE DIODE FUSE HOLDER WITH DIODE15A
Features Built-in Diode. 10A/15A/20A/30A fuse embedded into a waterproof fuse holder, solar connector lead on each end. Compatible with PV cables with different insulation diameters. Designed for a wide range of DC applications. Simple plug-and-play. Auto-lock equipment of male and female points...
richsolar.com
5PCS Solar Fuse Holder Copper Silver Plated Conductor for Cable AC/DC Interface 15A: Amazon.com: Tools & Home Improvement
www.amazon.com
Thank you.
Ali
