alvenegas
Hello all,
I have had a PV system since 2018 consisting of 18 350W solar panels with 2 MPPT60 charge controllers with a Conext XW+. I have recently installed an Insight Home and two EG4 14kwH Lithium batteries. Before I had lead-acid batteries. The thing is that I have been reading about the limitations of the XW+ with Li-ion batteries. I have been searching in the forums about the combination of the XW+ with Li-ion batteries and I cannot find much, as everything is related to the XW Pro. The XW+ is open loop, so I can technically see the EG4 batteries info through the Insight Home. I received from EG4 an instructions setup guide to use the RS485 port on the batteries to connect to the #9 and #11 ports on the 12-pin connector of the Insight Home. I followed their instructions and is working, but I still have some issues. The instructions states that I need to choose Li-ion as the battery type on the inverter's Battery Setup menu, and I need to specify it is an External BMS. If I do that the inverter complaints about a lack of communication. I checked the firmware version on the screenshots of the setup guide and it says 1.17. I have the 1.16. I tried upgrading the firmware to the current version (1.18) but that did not work, and I don't know why. But somewhere in these forums somebody said that firmware version 1.18 of the insight home didn't do well withe the XW+. After reading that I stopped trying to do the firmware upgrade. Has anybody gone through this process already that can help me out configure this properly? I asked EG4 for my particular situation but have had no answer yet. There must be someone out there that has done this already. Any help will be greatly appreciated. Thanks!
