Glamisduner
Just installed 4 100 watt panels in series on the roof of my toy hauler. My 6V batteries are still working after 8 years (We always leave the trailer plugged in). However I'm sure they have significantly reduced capacity at this point. I ran 4 renology panels in series and connected them to a Victron Energy 100 / 50A MPPT controller. Then the controller to a 4awg distribution block that also powers my 600watt pure sine inverter.
I'm thinking about joining the cool kids with their fancy Lithium batteries and have watched a bunch of youtube videos leading me here.
I would like to purchase something while the black friday deals are active.
Currently I have 2 6v 225ah batteries in series. They are 8+ years old. My Batteries are installed on the tongue of the trailer behind the propane tanks. I do not have a pass through area since we have a front Bathroom Model, so the new battery will need to be located there as well. It's a 28 foot Ragen trailer.
So I am looking at a Watt Cycle 300ah 12v or a Epoch 300ah (or maybe 460ah essential series). Cost is obvioiusy factor but it's ok if I should spend more on the Epoch. I realize if I pay $1800 I can get an Epoch one that will integrate with my solar controller. But is that really necessary $$$?
Epoch 300ah ($850) https://www.epochbatteries.com/products/12v-300ah-heated-bluetooth-lifepo4-battery-epoch-essentials
Watt Cycle 300ah ($499) https://www.wattcycle.com/products/wattcycle-12v-300ah-mini-lifepo4-battery?ref=aaezwkkc
If the battery goes into a metal box, I'm not sure how useful the bluetooth option would be, but I guess you could open the lid to check, and that's probably enough. I don't have a battery box selected yet, so I would appreciate any suggestions.
The cost difference is significant, and I believe I also need to upgrade the charging unit that came with my trailer? Or can I leave it, and just rely on the solar to top off the batteries for now? So if I get the cheaper battery, the money saved could go towards upgrading the charger....
Second I have a couple concerns.
TLDR: have 400 watt of solar. I will be mounting the battery on the trailer toungue. Wich Battery should I get? Will the heating pad be enough if I get the cheaper battery? Battery box recommendations? Any Concerns starting an Onan 4000 generator?
Thanks in advance!
Adding Pictures of solar MPPT install just because.
- Since the battery box will essentially be mounted outside on the tongue of the trailer, and we do camp in a few locations where me cooler ice re-freezes overnight I am wondering if I should just spend the extra $350 for the heated battery. Or could I just get something like a Facon RV holding Tank heating pad like this https://www.amazon.com/dp/B01N7QVBJJ? I would wire this to a switch so I could turn it off when not needed event hough it is thermostat controlled.
In these locations, the temperature is usually only dipping into freezing overnight, and it warms up in the day, and it only gets that cold sometimes. Still I don't want more problems than I have with my 6 volts. - Second concern is I need the battery to be able to start our generator. Now these all say they are not for starting, but I can't imagine they would work any worse than the 6v's for starting the generator.
Thanks in advance!
