jasowiii
I have a motorhome that has an existing inverter/charger, batteries, etc. I'm adding a $400 Renogy kit (4 panels, charge controller, cables).
My question is if there is an issue with connecting the charge controller (+) to the coach fuse panel input line??
The line is 2ga directly from the batt compartment about 10' away. This would make for a very easy install as the best location to mount the charge controller is next to the fuse panel. Also convenient for running to the PV input down from the roof.
Thoughts?/Concerns?
I realize this would "disconnect" the solar when if I actuate the battery disconnect switches/relays but I don't think I care.
Thoughts?/Concerns?
