Sgt Raven
- Feb 17, 2020
- 1,079
45+ years ago, when I was working at a gas station and installing batteries. I used a fine tooth 1/4" ratchet and socket on the terminals. After shorting it to ground a few times, I wrapped the handle with electrical tape and never had that problem again. If I was doing it today, I would use heat shrink tubing for the same reason. By doing this, if your ratchet slips out of your hand or you drop it, it may save you from sparks flying. Some heat shrink on the deep socket would help, too. It's along the same thing as electricians screw drivers are insulated.
