I bought the Dewalt DCE151B from Woot. It comes with no cutters. You must buy them individually, starting around $35. I bought a 2/0 cutter but the 2/0 welding cable was very difficult to push into the cutter. I then bought a 3/0 cutter thinking it would fit the 2/0 cable better. While the welding cable does go into the 3/0 cutter easier, the cutter is so large that it hardly cuts the insulation.
Here's my attempt at cutting 2/0 welding cable with the 3/0 cutter, with the cutting blade adjusted in as far as it will got.
I went back to the 2/0 cutter and put some muscle into shoving the cable into the cutter. It still didn't work.
I switched to my Klein Stripper tool and used the 3/0 cutter on it. This is the best I could do. It didn't seem to cut any of the strands but it did twist them. The result isn't clean enough and would require additional work with a utility knife.
The Klein has maybe 1mm of adjustment on the blade, which isn't enough at all. The Dewalt blades can be adjusted about 3mm.
The Dewalt 2/0 cutter. The sharp part of the blade is at about the 3 o'clock position. It's adjusted in as far as it will go.
I don't recall what type of wire the Klein cutter is rated for. The Dewalt cutter is rated for THHN & XHHW. These tools just aren't designed for welding cable. At least that's my experience. I'm back to using a box cutter.
