S sshibly Solar Enthusiast Joined Dec 8, 2020 Messages 529 Apr 9, 2021 #1 Batt > BMS Wire with RING connector > bolted to another wire What is out there to insulate this connection? ebikes use this but it has spots for 3 connections This is what I need to insulate: Attachments ring_nut.jpg 85.6 KB · Views: 10 Last edited: Apr 9, 2021
S sshibly Solar Enthusiast Joined Dec 8, 2020 Messages 529 Apr 9, 2021 #2 Another one, with a fuse, this is TOO bulky, I just need a small enclosure to wrap the RING terminals bolted togethers
S sshibly Solar Enthusiast Joined Dec 8, 2020 Messages 529 Apr 9, 2021 #4 JoeHam said: Large diameter heat shrink. Click to expand... need quick open removal capability, I have capton tape on it now
J JoeHam Solar Wizard Joined Dec 30, 2019 Messages 3,569 Apr 9, 2021 #5 sshibly said: need quick open removal capability, Click to expand... My pocket knife works quickly on kapton or shrink tubing ! ?
J JoeHam Solar Wizard Joined Dec 30, 2019 Messages 3,569 Apr 9, 2021 #6 For true quick disconnect I would use a WAGO or half of an Anderson PowerPole red/black pair. Last edited: Apr 9, 2021
John Frum Tell me your problems Joined Nov 30, 2019 Messages 15,234 Apr 9, 2021 #7 ^ Wago 221-612 Lever-Nuts 10AWG 2 Conductor Compact Wire Connectors 50 PK : Amazon.ca: Tools & Home Improvement Wago 221-612 Lever-Nuts 10AWG 2 Conductor Compact Wire Connectors 50 PK : Amazon.ca: Tools & Home Improvement www.amazon.ca
S sshibly Solar Enthusiast Joined Dec 8, 2020 Messages 529 Apr 9, 2021 #8 wago will not fit the ring connector, I want to retain the ring connector, something like a ANL fuse housing/cover but smaller that will fit the 10 Awg 6mm ring connector will be perfect
Q-Dog ¯\_(ツ)_/¯ Joined Dec 22, 2020 Messages 1,723 Location South Louisiana Apr 9, 2021 #9 Busbars & Terminal Blocks Dual or single power posts may do what you want.
