TL;DR:: for us it boiled down to substantial savings on the Corigy and the ability to do both Portrait and Landscape ... and set up 48 panels from Pallet to operational in less than 4 hours
We tested out both the PowerRacks and the Corigys ... and went with the Corigy's ... to be honest - if you are only interetsed in the Landscape - and you are NOT using really large panels -- then it was hamburger / cheeseburger .... coke/pepsi .... ford/chevy ... results ...
The Corigy's and the PowerRacks seemed to be about the same thickness and both seemed to be able to stack up to give us at least 5 years of warranty and 20 years of direct sunlight .... and honestly 90% of the container stays covered by the panel anyway ...
Both are super SUPER thick ...
But the Corigy's come in (2) models -- landscape and Portrait and from what we understand the PowerRacks only came in LandScape ....
Both are important to us becuase often we do not know the amount of real estate we are going to own out at these sites .. Each of our 8X10 Cargo Container Solar Generators w/ 48VDC 50kWH LiFePO4 systems we put together using the Solark15's (fricking awesome piece of hardware) takes on average about 48 (395W) panels each site to get to the 19,500W threshold the Solark15's can handle ..
and we are putting out nearly (60) solar generators in the next fiscal year ... which translates to about 3000 panels (thx
https://a1solarstore.com/) .... so we are looking for the lightest, fastest, cheapest way to do all of these ... almost all of the areas we put these on is desert so ground flatness is our friend ... also its extremely easy for us to simply scoop up dirt on one side and dump it into the containers on the other ... For those areas that are not flat we simply pour some gravel and make it flat ...
We like the Corigy's ability to go either Horizontal or Vertical ... and about half the times its easier to do Portrait and not landscape just to take up less ground ...
Also we purchase them directly from Corigy (I think that we pay about $18 for Landscape and $21 for Portrait) but we order them a Pallet at a time ... Each Pallet I believe has 62 of them .... Corigy won't do DDP but there is a very good transport company we use called
https://www.goldenbridge-intl.com/ that will get them from there to here .... when the smoke clears - delivered -- the Corigy are about 50% less than the PowerRacks ...
I think - but don't quote me - that the PowerRacks are about 90.00 each (
https://www.solar-electric.com) and delivery is I think about $300 regardless how many you order ... again ... i don't do the ordering so don't quote me at all ...
NOW with that said -- if you are nervous about dealing with international shippers and things (
https://www.goldenbridge-intl.com/ is HQ'd here in California) then I would go with the PowerRacks ...
Also another thing we liked about the Corigy was their ability to have two separate sections in their "tubs" ... we normally fill one with dirt, rocks, steel, old batteries, dead bodies, etc .. and often will use the other part for storage of parts and cables and things like that ... pretty nifty ...
I will see if I can attach some pictures and a video ... not sure if I can ... if not then I would drop
sales05@corigy.com a note and ask her to send you some info .. her English is great and her name is Nina ...
and NO -- i/we/us don't make a cent -- I don't know them -- BUT I will say that I can set up a 48 panel array in a matter of hours - start to finish .... and be done ... no digging .. no permits .. no OSHA or EPA ... and i fill these things with a skid steer and I'm done before lunch ...
