Hi everyone,
I’m currently running a 48V solar system and need advice on efficiently integrating two LiFePO4 batteries with different configurations:
Questions for the Community:
Looking forward to your thoughts!
Thanks,
- Battery 1: 15S (48V nominal, 54.75V max) 50Ah
- Battery 2: 16S (51.2V nominal, 58.4V max) 50Ah
- I have a PV array charging through an MPPT controller in my inverter.
- The inverter runs at 48V but can only use one battery at a time due to the different voltage profiles of the 15S and 16S batteries.
- Neither battery has enough capacity to keep the inverter running through the night, so the system shuts down before sunrise, and I have to manually restart it.
- I can’t parallel these batteries directly because of their different voltages.
- I want to avoid over-discharging the lower-voltage 15S battery or undercharging the higher-voltage 16S battery.
- I also need a solution that allows both batteries to charge efficiently without manual intervention.
- Has anyone successfully integrated 15S and 16S batteries in a similar setup?
- Any options apart from reconfiguring the 16S to 15S?
Thanks,
