Hi everyone!
I want to buy a small BMS for 24V lead acid battery. But I also want to integrate the charge status, current wattage, etc. into my home network (via lan).
How can I do this?
I know some BMS have bluetooth or an RS485 interface but need proprietary software to work with.
I would like to connect the BMS with for example a raspberry and the raspberry with my network, so that the raspberry can publish the data from the BMS via MQTT to other devices.
Thank you for your help!
I'm sorry if this topic is already discussed - I haven't found it.
How can I do this?
