copec
- Jan 23, 2021
- 335
Solar heat pump solution for water, pool heating
U.S. solar thermal specialist Fafco is set to launch a new photovoltaic-thermal heat pump solution for water and pool heating. The system consists of photovoltaic-thermal panels, a 5 kWh thermal battery with a heat pump, and an electric hot water heater.
www.pv-magazine.com
Like many of you, I've been interested in solar, heat pumps, geothermal, etc. for a long time.
I've been planning to build something like the product linked for years, where I put some pex/aluminum heat spreaders on the back of all my panels, and a pump circulates that to one tank (probably IBC totes with some basic insulation), and then home built liquid/liquid heat pump to a thermal storage tank for heating and domestic hot water. According to my calculations I can opportunistically gather and store plenty of low grade heat without dedicated insulated glazed collectors, enough so as to have a better CoW than geothermal without digging up my suburban yard for some geothermal.
Check out this forum if you are unfamiliar with it: https://ecorenovator.org/forum/forumdisplay.php?f=10
