RCinFLA
Solar Wizard
- Jun 21, 2020
- 3,560
If it is really 0.36 milliohms near 25 degs C that is pretty poor for 280AH cell. If you have a current shunt in 0.1 to 0.5 milliohm range you can check your meter accuracy. (shunt mV divided by current rating = shunt resistance, 75mV/500 amp = 0.150 milliohms) Always check on battery terminals directly, not on top of bus bars. Low temp increases Rs (see attached pict) Full charge is a bit higher Rs. 50-80% SOC gives best Rs.
Most of degrading side chemical reactions that increase cell Rs also ties up lithium reducing capacity.
