overisland
Hello, my name is Tony and I picked up this Basecamp 20x a few weeks ago. Working on building out the solar to be a bit more robust so I can dry camp more often.
The basecamp 20X comes with:
300w (3x100) Merlin flexible solar panels
Victron MPPT solar charge controller lithium capable (not sure exact model)
Power converter
Stuff I have in the garage/on order:
Renogy 2000W inverter
Battle Born GC heated batteries x 3
Still need to order:
BMV-712 Victron smart shunt
cables to support battery connections and inverter connection
This will all be hooked up under the front dinette, where the current AGM batteries are. Plan to wire the 3 batteries in parallel.
I have a few questions:
1. I am unclear on how to wire the inverter to the converter. What I want is to be able to turn the inverter on while I am dry camping, and that power my converter, effectively letting me run everything besides the air conditioning and the microwave. The renogy 2000w inverter does have alternating current connections. I have read about some people having a circuit just for the inverter, but I am lost on this.
2. Battle Born recommended 1/0 or 2/0 wiring, any additional input on this recommendation? My batteries will all be mounted next to each other, and the inverter will be within a foot of them.
3. What size fuses / circuit breakers would I need and why would I want one or the other? Seems to reason to me that a circuit breaker would be desirable as I could reset it.
Here are a few pics:
Power converter
