Hoop33
It's a long story, but I will try to keep it short. I have been working with a solar company in my area for the past three years to install an off-grid solar system for my pole barn. I am only using the solar to run a few LED lights and maybe a fan, three or four days a week for a few hours. Not much of a demand on the system. During this time I have replaced 4 inverters and 4 lithium batteries. Each time we replaced the components, the system would work about a week, tops. The last time was about four weeks ago. I never really got involved because I paid them and it was there job to get it right. Until this last time. I am not an electrician or a solar system installer, but fairly handy and most of time I can figure it out.
Four weeks ago, the system worked fine for about a week. Then I noticed the inverter would not power up, again. The battery was fine at the time. Showing 100% charged and 13.9v. About three or four days later I notice a light blinking on the charge controller. It would blink and then stop blinking. I checked the charge controller and there was an error code E2. Battery over charge. The battery was warm, but not hot. Later that day the light was still blinking. I checked it and the battery was very hot and began to bulge on the sides. I disconnected the solar panels and then the battery. Again, dead inverter and battery.
So, basically I have taken inventory of all the components used to build my solar system. Also, I may note of the wiring sequence. Here's my list of parts used. 6 - 200 watt / 24 v solar panels, 1 - Renogy Rover 100A MTTP charge controller, 1 - aims power 3000w / 6000w Pure Sine Power Inverter, and 1 - 12.8v 300ah LiFePO4 Lithium Battery. After checking the wire sequence I noticed something that didn't look right to me. Here's how it is wired. Solar Panel to Charge Controller then the battery leads at the charge controller go to the inverter and the battery goes to the inverter as well. At this point I research wire diagrams for an off grid solar system. I found no one had wired their system that way. It should be Solar panels to Charge Controller to Battery to Inverter.
It appears I'm going to replace the inverter and the battery, again. My question is the charge controller damaged? Through this whole process, I have never replaced the charge controller. Or is it simply the wiring sequence that's the problem? The Renogy charge controller manual clearly states to not connect the charge controller to the inverter. I am open to all tips or suggestions. I want to make sure it's right this time before I put everything back together. Thanks for your help!
