Inverter / Charger
Zonphirst
Hi all - I'm looking for thoughts on whether to separate the inverter from the shore power charging or to have a single unit to do this job. Any recommendations if it is recommended to use a single unit?
rmaddy
Full-time Solar-powered Trailer Life
USA
An inverter/charger is certainly a lot simpler than setting up a separate inverter, charger, and transfer switch.
Something like a Victron MultiPlus is an excellent choice for an inverter/charger. I'm extremely happy with mine.
But the decision could be affected by your specific situation. Post a bit more about your planned setup. Is it for a completely new system or retrofit into an existing system? Mobile? Residential?
Zonphirst
rmaddy - I have a new build sprinter. My plan is to run a solar array in parallel (400w) and alternator through a Renogy 50A controller / charger and into a Victron Lynx distributor with the 200Ah Lithium battery on "the other side". Had intended originally to have a separate inverter and shore power charger. Wanted also an inverter that I could run hardwires through and not just plugs. Came across the Renogy 2000W inverter / charger all in one and it looked appealing as it was cheaper than the Victron and still seemed to do the job.
Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
Rural NE Ontario Canada
PLEASE do your research on Renogy ! They have a Reputation and not a good one.
I have to say BUYER BEWARE ! Search here about problems with their support/service & product quality.
tjoiner1986
Sheffield, AL
What would be a good recommendation for an inexpensive inverter/charger that's not bad quality?
I ask because, like @Zonphirst, I also have the Renogy DCC (except mine's the 30-amp model). For a moment, I was eyeing the MPP Solar 1000-watt all-in-one but it doesn't support alternator charging. Knowing Renogy's "hit or miss" reputation, I opted for a Giandel 1200W inverter but now I'm considering my shore power options.
Perhaps I would have been better off getting the MPP Solar 1012LV-MS and then adding a DC-DC charger so I could charge off the alternator?
MisterSandals
Participation Medalist
Silicon Valley
I too am not a Renogy fan but if you already have this, my impression is that its OK as an alternator/DC-DC charger but falls down horribly when combined with or used exclusively with solar.
What will your array be in parallel with? Or are you talking about panels in parallel (which sounds like an odd plan too)?
