scalabroni97
- Nov 2, 2021
- 2
I am trying to power a camper entirely with solar. I have a Renogy 3000w pure sine wave inverter directly wired from the ground, neutral, and load posts to a 30 amp camper outlet. When I plug the campers shore power (which is for 110/125v, 60hz, 30 amp supply) into the outlet, the inverter gets an error.
Do I need a bigger inverter to support 30 amps?
Do I need to disconnect the converter in the camper? I've attached a picture of the converter inside my camper.
