whomba
*Question* - I think one, or both, of my batteries are bad. Looking to either 1) confirm I need new batteries 2) figure out how I can 'make them healthy'. I'm also looking to understand how I can prevent this from happening in the future.
*Problem* - My Renogy 3000w Pure Sine Inverter is beeping when under load (around 20w from charging 2 lamps, 2 phones and water pump). Based off my research it appears it is likely because the battery has low voltage, this is because my renogy battery monitor is showing the battery as being ~ 10.9v under load. The Charge controller is flashing error code `E3`, Battery health display shows 96-98% full.
*Background* - I've recently purchased an off-grid cabin which has a solar setup in the mountains in the pacific northwest (think lots of clouds in the winter). It appears that the prior owner bought everything from Renogy, the current system has:
1. 3000w Pure Sine Inverter
2. 40a Rover mppt charge controller
3. 4x - 100w Solar panels
4. 2 lead acid Interstate Batteries, groupsize 31t, with a creation date of 6/22
5. Battery Health display (shunt?)
We go out to the cabin once every couple of weeks, outside of that, the entire system is on/connected but no load is on the system. Approximately 2 weeks ago while I was there, everything was fine and worked as expected. I ran my cpap machine all night, charged a bunch of stuff and it worked great. This past weekend after we turned on the water pump, and plugged in our usb lamps (total load < 20 watts) after 30 - 60 minutes, the inverter began beeping and shut down. Ambient temperature in the cabin was ~ 40ºF The following day when there was a tiny bit of sun (charging < 10w) I tried again - this time 20w was fine, but bumping up the load to ~ 30w caused the voltage to dip, fault alarm to go off and inverter to shut off. The battery health shows it's 96-98% full, under load of 12v marine water pump, the voltage on the batteries show a dip from 11.6v ish to 10.8v.
So, at this point, I'm trying to determine if the batteries are bad. I am unsure if
1. I just need new batteries (and should swap those lead for LiFePo4)
2. I can 'make them work' by attaching to a generator to charge them up (didn't have a generator to get them charged, so haven't tested)
3. something else?
Additionally, is there anything I should be doing *differently* in the future to prevent this from happening? This is my first time doing solar, so unsure if this is par for the course.
It's quite unfortunate that I don't have internet out there and it's a few hours away so my feedback loop for testing is a bit miserable, so I'm writing this not near my system.
1. Pic 1 - health display sitting idle
2. Pic 2 - entire system
Obligatory - no wires are loose, nothing is hot, etc.
3. something else?
