Hi
I've a fairly new system with PVs, completely off the grid
Now that the weather is darker there's not enough charge during the day so I've bought a petrol generator, it's apparently 6.5kw, 110/230v, after connecting it to the inverter as the AC the AC input light and bypass light are flashing, it's not actually giving power to the system and not charging batteries, I believe settings on inverter are correct like"both solar and utility will charge batteries as first priority" and input is set at 230v and 50hz, tried different max input amps from 5 all the way to 60 and still nothing, now the inverter does see the generator, it fluctuates a tiny bit, the acceptable voltage of inverter is adjustment 170-280v, generator gives about 230-240( tried switching to the 110v as well on generator and inverter with no difference), yet I don't know what's acceptable frequency range, it says 50hz, generator, depending on speed setting, provides, 49-50.5Hz on low rpm to 51.5-53Hz on higher rpm setting, the inverter has a separate AC input setting marked as GNT I believe, in manual it states it's for generators 230v(170-280v range) due to them being more unstable, tried this too and still nothing, just blinking AC input icon with blinking bypass icon, any ideas how to get it to work? Should I get a voltage stabiliser? Will that stabilise frequency as well?
