esands
Hello,
I have a Class-C that I'm going to install an EG4 3000 Inverter, Solar Panels, and 4 48v 50ah golf cart batteries.
Question for the EG4 which has a grounding screw on the bottom. Do I run a grounding wire from the Class-C chassis to that screw?
Also I'd expect the Neutral Ground bonding must be enabled on the inverter. Or will this be a problem when hooked up to shore power?
