You could add on finer screen, would have to clean it more often.
Most equipment has screens to keep out larger things. Some is sealed, with fins to transfer heat. Motors called "TEFC" (totally enclosed fan cooled) are this way. Sunny Island and most Sunny Boy have SMA's "OptiCool" design, which is a sealed volume for electronics and a fan cooled 3R compartment for transformer with fins to cool the electronics. They may have an internal fan as well to cool some components.
The Sunny Island -US models aren't quite sealed because they have a mechanical breaker and SD card. I sealed that with sheet of silicone. New European models 8.0H are fully sealed because they don't have those parts, only membrane keypad and display.
3/4 of the way down is a drawing:
Outback has "GTVX" (vented) and "GTFX" (sealed) models, with different cooling capability.
"Condensing" humidity would be a shorting problem. Otherwise it is Paschen effect, each gas supports breakdown at some voltage depending on pressure x distance, basically the number of molecules between electrodes.
So long as the water remains as H2O vapor in the air, it has only slightly lower breakdown voltage than air (which is predominately N2 and has same breakdown as N2). Gasses like He, Ne, Ar have significantly lower breakdown voltage. (and blend of Ne + Ar shown considerably lower.)
Download scientific diagram | The Paschen curve shows the dependence of the breakdown voltage, Vt [V] on the product of gas pressure, p, and the minimum breakdown distance, d, for four molecular gases composed of H2, H2O, CO2, and of air. The classical Paschen curve depicted here, has a minimum...
www.researchgate.net
Download scientific diagram | Paschen Curve for various gases [4]. from publication: The ratio of enthalpy minus piezoelectric energy versus the sum of the 1st ionization atomic energy in N moles of an ideal gas in an isochoric process. | Andrew Somorjai May 12 th 2015. The ratio of enthalpy...
Some of those curves are significantly different from what I remember seeing, which was voltages < 200V and < 100V (at some pressure and distance), like this:
German physicist Friedrich Paschen improved our understanding of how electric current flows through gas. Learn about his life and work here.
www.comsol.com
Lowest for air was at something like 50,000 or 100,000 feet. A problem for rockets. Your location is just part way down the curve on the right hand side.
