Steve_switch
- Jun 14, 2020
- 13
I have a Residential home build solar project that is off grid. I recently purchased a Samlex PST-3000-24 inverter am try to control the On/Off power switch to this unit with a remote mounted relay. In the Owners Manual page 44, a diagram shows the 4 position Terminal Block, showing 3 methods to operate this inverter remotely.
I set up my relay as shown in figure 8.2(a) first. At first it operated as expected, the inverter turning on when the relay contacts closed and off when the relay contacts opened. After operating fine switching on and off just like advertised for as long as I chose to have it on, I started to notice my inverter turn on without the relay energizing. So I double checked my relay circuit, then triple checking for good measure. I didn't find a problem in my relay circuit. My relay is located about 3 feet from the inverter.
So I thought well maybe the connection between pins 1 and 2 on the Samlex was super sensitive. I'll try method 3 shown in figure 8.2(c). Using my 24v batteries supplying the DC input into the PST-3000. I connected the Positive Terminal of the battery, through a 1 amp fuse, to my NO relay contacts, and into pin 3 as shown. I had a similar outcome as the first connection method. The connection seemed to work as my relay would control the inverter On/Off power. Then I again began to notice a seeming flicker of the Inverter power on LED, then off again, happening without the relay being energized. This almost seemed as if there is a bad connection somewhere in my circuit. I double and triple checked every connection. I didn't find a bad connection. Lastly, I connected the remote On/Off shown in the method in figure 8.2(b), I made all connections as shown, and even before I could make the connections to my relay, the inverter turned on. I stopped right there.
what the heck is happening here. I have a call into Samlex, they have not returned my call. Can anyone shed some light on this issue?
