timselectric
- Feb 5, 2022
- 25,426
Moonlight, can actually produce power.
Just not much, compared to daylight.
Yes that is a great feature. Of course it still doesn't work at night. Also if you have to meet Rapid Shut Down requirements it has to be disabled.Sunny Boy does that, 2000W 120V available when grid is down but sun is up from "Secure Power" feature of newer models.
By “inverter” I think you are referring to an AIO- All In One- unit which usually contains a solar charge controller, a ‘utility’ charger, and an inverter at a minimum.Maybe but that would mean adding yet another feature to look for for my inverter, which is that it should be able to accept any battery.
I’d shop further. There’s plenty of decent equipment that let you choose your own batteries; some available that will integrate with their own brand battery will also accept other batteries but just not feature the battery status/reporting integration capabilities.the 2 models of hybrid inverter my provider showed me both use only proprietary batteries
I haven’t ever seen a charging wattage, but a couple times under bright moon when I was using the AN30, the display indicated the sun was out. An actual 40W would be pretty cool!We laugh but sometimes my charge controller does say it’s charging with 40w at night when the moons bright. Probably just a false positive
Yes, I know, in fact I'm not planning on making my installation next week, I'm thinking maybe 6 months to one year from nowJust need to do much much more research, before you spend any money.
There's many ways to skin a cat.
This stuff can be done very cost savvy.
Yeah that's what I'm referring to.By “inverter” I think you are referring to an AIO- All In One- unit which usually contains a solar charge controller, a ‘utility’ charger, and an inverter at a minimum.
The inverter merely takes battery power and turns it into 120VAC (or 240V or whatever it is made for) to output for use. Inverters are generally designed for a specific battery voltage: 12V, 24V, 48V DC
The solar charge controller- SCC- is what charges the battery/batteries. Within its designed voltage, any good AIO or standalone SCC will be setable/programmable for whatever battery type/chemistry you use.
Yeah but your system was totally off grid, right ? What I'm looking for is a grid tied system that can also power my house by solar energy only in the event of an outageI run my washing machine from solar panels with a $20 inverter and no battery. A cloud passes and it will stop. I just press start after it is gone and the machine remembers where it was. No need for expensive technology.
Yes it's the kind of feature I want but my problem with it is that from what I understand, it's limited to 2kWSunny Boy with Secure Power could fit the grid-tie plus occasional backup requirement pretty well.
You're making a mistake in your thinking ........ off grid is the way to go.Yeah but your system was totally off grid, right ? What I'm looking for is a grid tied system that can also power my house by solar energy only in the event of an outage
I'm with you on this. I don't want anything to do with the grid. Other than to use it if I need to do any maintenance or upgrades. And then, kick it back to the curb, where it belongs. lolYou're making a mistake in your thinking ........ off grid is the way to go.
Why do you want to provide power to the grid?
1. The grid doesn't want your power.
2. The grid won't pay much for your excess power.
3. Grid tie costs a lot more money in installation, inverter and permissions.
4. When TEOTWAWKI happens, and the grid ends forever, you'll still have no power.
Best to use a cheap off grid inverter with no battery.
1. Most will use solar, then top up any needs from the grid.
2. You can add a battery later.
3. You'll still have power after TSHTF.
I have 11.8Kw of solar panels and I get between 1 and 2 Kw per hour production on cloudy days. As long as it is light you will get some production.Havnt seen an inverter yet that can do that. But if the array is over sized then it can power some loads when cloudy
Yes the electric companies are that way.Delta H6 hybrid inverter will supply 6kw as a grid tie inverter and will also supply 6kw to offgrid love ads without using a battery. I have one I’d be willing to get rid off. I used it for one month before I realized my electric company wasn’t 100% honest about their solar program.
IndeedI have 11.8Kw of solar panels and I get between 1 and 2 Kw per hour production on cloudy days. As long as it is light you will get some production.
I didn’t sign any kind of agreement so I shouldn’t have expected muchYes the electric companies are that way.
Well it's true they don't pay much but that's still enough to be worth it as long as I do the installation myselfYou're making a mistake in your thinking ........ off grid is the way to go.
If you choose grid tied without battery backup.Well it's true they don't pay much but that's still enough to be worth it as long as I do the installation myself
For 6.5kW of solar panels + supports to mount them + the inverter, the electrical box, cables and everything, I'm at about 5500€
I should be able to sell unused energy for about 0.06€ per kWh, or maybe 0.1€ if I manage to find an electrician who would agree to help me
There is this stupid thing in France, for the main electricity provider to buy your energy, your installation must be done by a certified electrician. You can't do it yourself and then pay someone to verify it. Then your only option is to sell the energy to other providers for cheaper. To be honest I think the 0.1€/kWh is in part paid by the government as some kind of aid, but still. Paying someone to make my installation would cost me easily 3 times as much so that's not worth it
Anyway, selling my surplus is a way for me to justify a bigger installation, more powerful, in the long term it will be more profitable and in the mean time I'll have more panels to work with in the event of a power shortage
Grid tie using batteries is the way to go if grid power is connected to the house.You're making a mistake in your thinking ........ off grid is the way to go.
Only if there is no sun or if the inverter does not support it (and most of them don't)If you choose grid tied without battery backup.
When the grid goes down, so do you.
True, but that's going to cost you more.Only if there is no sun or if the inverter does not support it (and most of them don't)
But some grid tied inverters are able to provide power from the panels to the house in the event of an outage even without battery, this is precisely what I'm looking for
Sadly all nonsense.No I didn’t come up with all that but I agree with all of it
