Thanks everyone for the input. Grateful.
I'm still researching hard as I want to place an order for an inverter on the 1st of August if I can find the best brand/model to buy.
I plan to install a Leaf battery pack so will need to use an inverter that supports HV battery packs of up to 400v. So that limits the models to only a few on Dala's list posted above.
I also heard that it will never get certified for grid tie with a Leaf battery attached anyway, right? So that pretty much makes my decision to be off grid already a foregone conclusion, right?
Or should I still try to get an inverter that could be certified should I ever remove the Leaf battery and go with something that is approved? Probably not a bad idea to do this if at all possible if I can.
But...
I think I'm finally understanding the difference between single phase, split phase the three phase inverters. Each phase is just one more 100-120v channel of output? So do I have to balance my loads on each phase when in use to be somewhat close in order for the inverter not to freak out?
If not, then I could just run half of the outlets on each channel separately for normal 100-120v loads?
So if I'm off grid anyway, I guess it doesn't matter that I'd need to stick with a single phase inverter anymore? I could just choose any brand and any of the three? Single phase, split phase or 3 phase inverter and just distribute the outlets equally between the phases? Or what am I not understanding here?
All my devices are either Japanese 100v/60hz or USA 120v/60hz.
If so, a three phase inverter would give me the ability to run heavy duty equipment in my garage shop like welders, etc., right? Then regular 100v outlets as well if I split up the phases?
IF so, then it might be easier to go with a split phase or three phase model, perhaps? More options that way it seems.
Perhaps there's a YT video that explains this easily I could find with more effort...
I guess if I'm off grid I also wouldn't be limited to having to find an inverter that supports 105v/210v 60hz output to match Japan's West grid system here.
@Daddy Tanuki You also mentioned not to go over 10k for an inverter as Japan will then demand that I sell all my power back to them if grid tied?
That's not a limitation if I'm off grid as they won't care, right? Also, is it nowadays 20k as per the below link?
https://www.jet.or.jp/en/products/protection/index.html seems to indicate that it is now up to 20k certification available
