Do you know if the Multiplus Compact will independently control charging and discharging via the VE.Bus? I am still getting the pieces for my system and have the Multiplus Compact and the BVM-712. I am thinking I will need a GX device to play traffic cop between the various Victron devices I have planned.BTW: I have played with the 2-signal BMS assistant on the Multiplus Compact. I can confirm that the assistant will let you use the Temp Sensor input to either control the charge on-off or the discharge on-off. It just won't do both like you can on the regular MultiPlus.
I have not set up the relay to try to control the charge using the remote control inputs, but I see no reason it would not work.
Multiplus 24/2000-70
BVM-712
100/20 Smart Solar MPPT
Orion TR 12/24-15 Smart Charger
I want to be able to seamlessly transition through solar, alternator and shore power charging and have the Multiplus disconnect properly on over discharge without ever banging into the BMS voltage limits on charging or discharging.
