richard barton
- Jul 5, 2020
- 2
does anybody recomend a 12 volt 240 AC inverter for the UK? needsto be on 24/7....thanks should ass 2000 kw plus......
What’s the law in the UK regarding certification of 240V circuits? Will yours require any?thanks guys....I meant 2000 watts......I have the low battery auto switch over but dont like leaving the inverter 24/7.....any answers?...I am only interested in UK 240 AC stuff........
240V @ 60Hz split-phase is the U.S. standard. Pretty sure the UK is 230V @ 50 Hz, so don't accidentally buy one that won't work in the UK....does anybody recomend a 12 volt 240 AC inverter for the UK? ...
Your MultiPlus has a 'search' low power mode and at only 3W quiescent draw I doubt very much you'd ever flatten a battery. I mean you could probably fart in the general direction of your battery and re-charge it more that the MultiPlus would use.thanks guys....I meant 2000 watts......I have the low battery auto switch over but dont like leaving the inverter 24/7.....any answers?...I am only interested in UK 240 AC stuff........
