1201
Net zero
I hadn't seen that. Thanks. I do believe I have a v2Correction, the data sheet does state the differnce between V2 and V3 inverter, in the output data section, see attached screen shot, missed it on my phone earlier.
I don't think we can fault signature solar for this one if growatt did not communicate to anyone that there have been changes to the inverters. As much as I love my growatt inverter their documentation has been abysmal to put it mildly.
@saenns does your inverter have these backup outputs labeled?View attachment 201971
Hi! It looks like you're already connected with tech support but if you have any other questions or concerns, please don't hesitate to reach out to me!
@MajicDiver can you refer me to sellers who offer v2?The documentation is actually available on the Growatt website. Also on the Growatt utube channel. Yes, it is lacking a lot in detail, but anyone selling the stuff should provide the documentation that is actually available - in this case SS is not. There are other sellers who do.
I have two V2 inverters. I can give you 3 recommendations for where to buy.@MajicDiver can you refer me to sellers who offer v2?
Thank you, MajicDiver. I bought a replacement from Self2Solar. Jesse there was very helpful and ordered a V2 for me from Growatt which is working well with the ATS.I have two V2 inverters. I can give you 3 recommendations for where to buy.
Absolutely! If you could send me your name and email address, I can get you an update!Thank you, MajicDiver. I bought a replacement from Self2Solar. Jesse there was very helpful and ordered a V2 for me from Growatt which is working well with the ATS.
@SignatureSolarJess can you please help me with the RMA? Signature Solar received the V3 on 6/18 but I haven't received the refund yet.
Hi @SignatureSolarJess, sorry I missed your response. I was told on several occasions since July that a check was coming, which eventually it did on 11/14 but it turned out to be for just $498, which is $998 less than I expected. I will send you my information by private message, I would really appreciate any help you can provide.Absolutely! If you could send me your name and email address, I can get you an update!
Thank you for reaching out! I'll get with you in the PM!Hi @SignatureSolarJess, sorry I missed your response. I was told on several occasions since July that a check was coming, which eventually it did on 11/14 but it turned out to be for just $498, which is $998 less than I expected. I will send you my information by private message, I would really appreciate any help you can provide.
Be careful with the SYN-200. If you have AC connect, you can't have any solar panels connected to the MIN.I have a MIN 1400TL-XH-US and an ATS-11400-US purchased from Signature Solar. The inverter refuses to supply power to the ATS. When grid disconnects, it enters standby mode with warning code 300 (no utility) or 607 (abnormal communication with off-grid box). No voltage on the backup terminals under any conditions.
I spent about 8 hours troubleshooting during a power outage yesterday. Finally Growatt tech support concluded that I have V3 inverter (P/N PV01.0083600) which is not compatible with the ATS-11400-US. I either need to replace the inverter with V2 (P/N PV01.0072901) or replace the ATS-US with an SYN-200-XH-US.
I do not understand how this is possible. The manual for the MIN 11400TL-XH-US on the signature solar product details page shows the ATS-US as of today, over one year since I bought it. How could I possibly find a V2 inverter now that presumably it's been replaced by V3, and the P/N is not specified by the seller? Why would V3 break compatibility with such a simple interface? All it needs to do is apply power to the backup terminals... which apparently have no purpose because the SYN connects only to the GRID terminals?
I am extremely frustrated. Best case scenario, Signature Solar compensates me for the ATS. Then I need to pay for the price difference with SYN, labor to replace it, permitting etc... SYN is bigger so it won't fit on the wall where the ATS-US was. Now I have to back up the entire house, not just my critical loads panel.
Any tips for how to make this work? Or escalate with Growatt Tech Support? Or Signature Solar Customer Service?
I believe you are incorrect. Can you explain why you think that is so? I have ac coupled my MINs a number of different ways and have had zero problems. What exactly have you tried to do that doesn’t work?Be careful with the SYN-200. If you have AC connect, you can't have any solar panels connected to the MIN.
It appears thats only if the other inverter is something other than a growatt XH-US (because the SYN would not be able to communicate with it) Note that the documents you are discussing are for putting a SYN into an existing system just to add a battery.Also check out this pptx doc below
