xristostsilis
- Mar 24, 2022
- 100
I have a phocos 5kw inverter and I am trying to get my lifepo4 batteries to work with it however I saw here that I have to set absorption voltage to 48v. Is this the same parameter as "Boost battery charging voltage" (page 30 menu 26 on the manual) on my inverter?
so to sum up should me settings be (16s 48v):
I hope someone knows the answer to this one as I can't seem to find a solution online
off-topic:
Also does anyone know what is the "RS-485 (MODBUS RTU) battery" under menu 5 page 27 of the manual? I am trying to find a solution to communicate the JK BMS to the inverter. I have already found that I can do it via solar assistant but it would be great if it could work directly with my inverter.
FYI: phocos 5kw inverter is basically a rebranded version of voltronic 5kw
- (menu 26) Boost battery charging voltage: 58V
- (menu 27) Floating battery charging voltage: 54.4V
- (menu 29) Low voltage disconnect: 42.8V-48V
off-topic:
