Is EPEVER MPPT solar charge controller capable of low temp shut off?
Jamie.sanders
I'm new but saw an interesting trick, your inverter has heat sinks on it because it produces heat, mount it below the batteries
to help keep the batteries from freezing, add a small box or plexiglass cover or something to help hold that heat in.
Tecnodave
Im currently using flooded lead acid batteries so no way am i going to put my electronics anywhere near that, the batteries are in a commercial laundry cart and separated from my power shack. I have a homestead and cabin in Alaska but i reside in sunny coastal California where i've seen snow only once in 30 plus years living in the Santa Cruz Mountains not more than a few miles from the big pond.......The Pacific Ocean...my problem is with excessive heat in the summer. My place in Alaska is only occupied in better weather and i bring up fresh batteries every trip and trade them away when i leave, no winter storage problems at all.
Banszi
Warsaw, Poland
I can confirm that my Epever Triron 40a Mppt does have a programmable low temp cut off that does work (tested using frozen salt water). I'm using the external temp sensor.
I'm very happy with this unit. I use the rs485 port to connect to Arduino. Works great.
Andy6ft4Tall
Can the Epever temperature setting be accessed using the phone App? Or does it need to be connected to a PC?
Jwcarter
OP: I have that exact same charge controller and just confirmed that the software setting stick once the MT-50 is plugged back in after setting the low-temp cutoff via usb cable. I don’t have pv connected so I can’t confirm fully but it looks promising.
interestingfellow
It certainly seems to behave like a cutoff. My testing procedure involves the following settings;
View attachment 56344 View attachment 56345
Then I confirm it's charging;
Then I stick the temperature probe in a thermos with ice and salt to bring the temperature below freezing;
At which point the controller and my bench power supply seem to agree that it's not charging from the solar input. (The controller says "Solar Status=Cut Out", "Charging Status=Not Charging", "Battery Current(A)=0.00", and "Battery Status=Under Min Temp." while the bench power supply drops to a negligible amperage draw.)
Here's a recording of that all happening; (Just the software side, since my desk is too chaotic right now to include in an actual video.)
I want to make sure that I understand.
IN "device parameter settings" it has -40 listed as lower limit. *This is for discharge AND NOT what I need to change?
In "control parameter" panel, it has "libattery protection" enabled <*THIS* is the setting that does the protecting?
Thank you!
Symbioquine
There has been a recent firmware update to Epever charge controllers
I saw that PDF before, but do you know where one can actually download the update and updater program?
