What is the Vmp and Imp of your panels?
Have you plugged those numbers, along with the wire distance, into a voltage drop calculator?
10AWG should easily handle the amperage if your panels are in 8S but you may be losing more voltage than you would with larger wire. But see what the calculator shows.
