KBurns
- Jul 4, 2020
- 9
I'm looking for a solution to use with the lv5048 inverter. When I discovered I needed more battery power to run the inverter, the first set of batteries were no longer available, so I bought the second set. Here are two different sets of batteries.
Two 24V A123 LFP Battery w/ BMS – (a123 8s5p)
Nominal Voltage: 26.4V
Voltage Range: 20V – 28.8V
Nominal Capacity: 2.45kWh (92.8Ah)
Configuration: 8S5P
Energy – 100% DOD, Nominal: 2.6 kWh
EV Energy – 80% DOD, Nominal: 2.1 kWh
Chemistry: LiFePO4 (LFP)
Cell Type: 20Ah Nanophosphate Cells
Cell Count: 40
BMS Specifications
Single cell overcharge protection voltage:
Min: 3.72V
Standard: 3.75V
Max: 3.78V
Single cell overcharge protection delay time:
Min: 0.6S
Standard: 1S
Max: 1.5S
Single cell overcharge recovery amperage:
Min: 3.5A
Standard: 3.6A
Max: 3.6A
Recharge current:
Max: 130A
Single-section equalization voltage:
Min: 3.55V
Standard: 3.6V
Max: 3.65V
Single-section equalization current:
Min: 35mA
Standard: 40mA
Max: 45mA
Single cell over-discharge protection voltage:
Min: 2.15V
Standard: 2.7V
Max: 2.8V
Single cell over-discharge protection delay time:
Min: .6S
Standard: 1S
Max:1.5S
Single cell over-discharge release amperage:
Max: 130A
Discharge protection current:
Min: 350A
Standard: 370A
Max: 390A
Charging high temperature protection:
Min: 85℃
Standard: 90℃
Max: 95℃
Physical Specifications
Length: 14.9in
Width: 9.6in
Height: 6.6in
Weight: 51lbs
Operational Specifications
Operational Temp Range: -22F...-30℃ ~ 131F...55℃
Storage Temp Range: -40℃...-40F ~ 140F...60℃
Two 48V - LifePO4 - 120Ah - 6kWh
Description:
A123 PERFORMANCE KIT: W. More Power! (6KWh!)
Using New LiFePO4 / A123 Cells, a 300A Fuse, Capable of a 2C Discharge rate – these two (2) Batteries in Series can power any 48V Solution.
It includes our newest BMS System, Thermal Management Solution, Triple-Safety Redundancy Features, and Anderson SB175 Connection.
Perfect for any 48V Lead-Acid Upgrade to maximize the performance of your intended application. At (24LB/kWh) this is the strongest, lightest and smallest 48V solution available.
Detailed Kit Specs:
Configuration: 2P
Voltage: 48V
Ah Capacity: 120Ah
kWh Capacity: 6kWh
Wh Capacity: 6000Wh
Kit Performance Specs:
Max Continuous Discharge Current: 130A
Max Continuous Power: 6500W
Max Discharge Peak Current: 252A (6 Seconds)
Voltage Range: 40 – 58.8V
Kit Charging Specs:
Suggested Charge Voltage: 58.8V
Max Charge Current : 80A
Temperature Parameters:
Charge Temp Range: 0°C – 65°C
Discharge Temp Range: -35°C – 65°C
Optimal Discharge Temp. Range: 15°C – 35°C
Storage Temp: -20°C – 50°C (Max 6 Months)
Safety Features:
BMS (Battery Management System)
Over Voltage, Under Voltage, Over-Current
(Thermal Management System), Safety Breaker (63A)
Kit Dimensions:
Kit Weight: 136 (LBS)
Length: 10 (in)
Width: 8.5 (in)
Height: 20 (in)
Configuration: 8S5P
Cell Count: 40
BMS Specifications
Min: 3.72V
Standard: 3.75V
Max: 3.78V
Min: 0.6S
Standard: 1S
Max: 1.5S
Min: 3.5A
Standard: 3.6A
Max: 3.6A
Recharge current:
Max: 130A
Min: 3.55V
Standard: 3.6V
Max: 3.65V
Min: 35mA
Standard: 40mA
Max: 45mA
Min: 2.15V
Standard: 2.7V
Max: 2.8V
Min: .6S
Standard: 1S
Max:1.5S
Max: 130A
Min: 350A
Standard: 370A
Max: 390A
Min: 85℃
Standard: 90℃
Max: 95℃
Length: 14.9in
Width: 9.6in
Height: 6.6in
Weight: 51lbs
Kit 48V WOLF - LifePO4 - 120Ah - 6kWh - BigBattery.com
This 48V Kit uses LiFePO4/A123 Cells and also includes our newest BMS System with an Anderson SB175 Connection and also provides you with 120Ah & 6kWh.
bigbattery.com
Detailed Kit Specs:
Configuration: 2P
Voltage: 48V
Ah Capacity: 120Ah
kWh Capacity: 6kWh
Wh Capacity: 6000Wh
Kit Charging Specs:
Safety Features:
Kit Dimensions:
Length: 10 (in)
Width: 8.5 (in)
Height: 20 (in)
