fromport
"Don't do it"
But fyi, most electronic components are rated with 5-10% tolerances, and most designs take that in to consideration. However, a lot of the stuff we are buying from China etc. is all over rated by 50-100% or whatever fits the marketing box. That's why the yt testing channels are so popular, imo. I have no idea about the Bluetti specifically, but it is expensive. Maybe film it so if it does go boom, you can get some likes?
If I had to, I would use the calculator above and not run the solar in sunny conditions when the temperature will allow for an over voltage condition. I wouldn't imagine it wouldn't be too often?
When it is during the day and there is any sunlight available, the charger controller/inverter will kick on and will lower the voltage because of the draw.
What I would be worried about is a freezing cold night with full moon.
Not enough photons to start the collection of energy, but enough to raise the voltage past the limit of the charge controller/inverter.
