Robbert
I live on Bonaire, and we have a pretty unique electrical infrastructure, provided by our electricity company.
We get the following
127 volts (yes 127 volts) single phase (blue and brown wires)
220 volts split phase (two brown wires)
Most of us only use 220 volts, since we receive 50hz (on both 127v and 220v).
In my current setup I have two MPP-Solar inverters with seperate Victron MPPT's.
The setup works perfectly fine. If there is enough solar and battery-power available the inverter puts out singe phase 230 volts and if the battery is under a certain level the inverter switches to grid and the house is powered via the 2 phase 220v, as supplied by the electricity company. All good so far.
I am considering to replace my current inverters with Victron inverters (the European models) and think that the power comming in from the grid might be an issue. The inverters deliver single phase 230v power to the house, but receive 220 split fase from the grid.
It is my understanding the Victron can be configured to supply some power from the grid to assist the inverter / or visa versa.
Since the output is single phase and the input is split phase, I think that combining that might cause a lot of smoke.
So I thought about the following two sollutions:
1) disconnect the Multiplusses totally from the grid
In this setup I can just connect the Multplusses to my current setup and the only thing I need is an additional Chargeverter
The Chargeverter will kick in at the moment the batteries are under 20% (or under a specific voltage), starts charging the batteries and the inverters just do their thing.
2) configure the Multiplus to not use grid feed-in and only charge
In this setup I don't need an additional charger and will connect the Multiplus to the grid and only use the Multiplus to charge the batteries, but not as a device that provides grid power in combination with battery power.
I know the first option will work for sure, and maybe that is the cleanest option, but if it is possible to go for option 2, I don't need an additional device that might break down and adds to the budget.
So preferably I go for the second option, but is that possible?
