Vigo
So I went off grid in May with 10kw of PV, 10kw of inverter (2x5kw growatt), and starting with very little battery (but now have more). I live in San Antonio Texas and have ~950feet of water line to the house, about 12-18" down. Suffice to say during the summer i was able to ignore the water heating issue because my 'cold' water was coming out of the ground fairly hot. Enough to put a little steam on the mirror after a long shower.
We finally got a slight break on the summer temps and suddenly i needed to get real and address water heating because now the ground water was only comfortably warm while the sun was actually up (before it was well into the evening!). My existing electric water heater was simply turned off at the breaker all summer, and I had plans to attempt some level of fancy stuff for water heating. I have a spare electric water heater tank, a backhoe, lots of open space, ability to do my own plumbing and wiring, and even have two commercially built ~4x8ft solar water heaters laying around (although one has broken glass). I was planning to do something cool, although i wasn't sure exactly what. Thoughts of pumps, sensors, insulation, valves, thermostats, etc all bouncing around in there.
But for the time being, i rewired my water heater from 240 to 120, unplugged the upper element, and put it on a $12 programmable din-rail timer relay running a grand total of ~5hrs a day at ~1100w. I also adjusted the lower thermostat from 120 to 125 for no real good reason.
My time windows (which i'm sure i'll tinker with a bunch over time), are:
7days/wk 12:30-4:15pm (1100w is very unlikely to bother the system in this time frame as i usually have ~6-7kw solar available and my 'base' load is around 3kw with the ac running, only way i can kill the system in this time period is putting multiple loads through the clothes dryer on high settings)
M-F 6:10a-6:30a (quick reheating before my morning shower)
M-F 6:00p-6:30pm (quick reheating before my 2 small kids' evening bath)
I kind of expected it to be crap. So far, it's...fine?! I haven't run out of hot water yet! And it's hotter than before, so it's definitely hitting the 125 i set the thermostat to. It seems to retain the heat very well, in spite of the fact that this tank is from 1994!
I'm just shocked that this isn't crap. I expected to struggle more. We will see what "winter" (i put that in quotes because of where i live) brings..
