I have two SOK 200Amp 12v Lithium batteries on order. I will connect them to my RV roof solar panels and replace my current RV (12v) converter/charger to a PD-4100L (12v) to provide DC to the van and also charge the lithium batts. I have a choice of 45, 60, or 80 amps charging.
The two batts will be wired in parallel. However each of the batt's internal BMSs (Overkill I think) are rated for limiting to 50AMP charging.
Is it safe to use the 80 amp converter/charger for recharging? Will the BMS's shut down if more than 50amps or will it simply limit the charge to 50amps. If not, would it be okay to use the 60amp for recharging? (the 60 amp is a two stage charge).
Thanks...hopefully I can get this figured out before the SOKs are shipped out at month end.
