thu
- Sep 28, 2020
- 2
I just bought a MPP Solar LV 3KVA-24V all in one inverter/solar charge controller: https://watts247.com/product/pip-lv2424-msd/?wpam_id=3
There's a video on that website where I bought the battery where Will Prowse is installing the 12 volt version of that all in one system, and at the end of the video shows the 24 volt version of the system that I bought. He mentions that you can just connect the 24 volt system to 2 battle born lithium ion batteries (I assume in series to since each of the battle borns are 12 volts).
But when I got the MPP Solar LV 3KVA-24V the manual in table 3 lists:
Bulk Charging Voltage Flooded Battery: 29.2 AGM / Gel Battery 28.2
It does not list lithium ion battery as one of the supported batteries. Does anyone know if the MPP Solar LV 3kva-24v inverter/charger works with lithium ion batteries?
