Okay, so I have 4 x 12v 100ah Renogy smart arrived today and will be in parrallel. My inverter is 3000w Meanwell. Using 3/0 cable and total path of cable lengths is under 2 meters total path. My inverter will never really exceed 2200w with single devices only in caravan. I was originally told no fuse needed between batt and inverter as inverter has input (12 x 40amp) fusing. However on reading these forums, I believe I should have a mega fuse on positive side from batt bank to inverter for batt and cable safety. Could I use a 300a fuse which appears to be similar to cable rating for 3/0 (95mm is the metric cable) or use a 350a fuse here for more wiggle room. Any advice appreciated before I buy this part of the build.
