Jack D
Hi Guys,
I have an EcoFlow Delta 2 power station that specifies its solar input as 11-60V, 15A and 500 Watt maximum.
I already have a 575 watt solar panel. It’s data sheet specifies:
Voc 52.32
Isc 13.89
Vmp 43.85
Imp 13.11
Pmax gain 0
When I have run the numbers it looks like even in cold conditions and perfect sunlight the V falls below 60V, but only just!
What I would like to know is whether my calculations are correct and this is safe for the power station. I’m trying to save myself re buying a smaller solar panel, but at the same time it’s not worth damaging the power station and potentially voiding its warranty. So ultimately should I bite the bullet and buy a 400 watt solar panel that falls comfortably within the power ranges and still gives the required charge comfortably.
Any advice and how you came to this conclusion would be greatly appreciated.
Jack
Voc 52.32
Isc 13.89
Vmp 43.85
Imp 13.11
Pmax gain 0
Jack
