Is plug-in solar coming to the US?
Wait, legal or illegal?
I'm amazed these could ever be UL listed. With one connected to a circuit you can easily overload said circuit feeding it from both the grid and solar if there's a heavy load (or short) elsewhere...
Sorry, it's legal.
Solar balcony systems are pretty popular in Germany.
The Germans limit the AC output to 800W, and Utah limits the AC output to 1200W.
And household circuits in Germany are commonly 3,680 watts (16a @ 230v)
So, 800 watts is ~20% of the circuits rating, an overload that the circuit will be much more likely to survive.
Vs the Utah spec
Common household breakers are 15 amps (or maybe 20) at 120 volts, so 1800 watts
1,200 watts means you could overload the circuit by 66% if you only plug in a single one.
From the snip provided Utah doesn't limit the quantity of 1200 watt systems.
I'm kind of annoyed they specifically called out a 120 volt outlet as a requirement. Why limit it to a 120 volt outlet? You could plug it into a 240v dryer outlet and have a dedicated circuit that wouldn't be easily overloaded.
I do think this possibly a beneficial product, but plugging it in to a regular wall outlet seems like it could be problematic.
Let's see how many scenarios we can come up with, using this device, that would be dangerous.
One way I can think of would be plugging two high draw appliances into the same outlet, with this device feeding a separate outlet on the same circuit. But what happens if a branch circuit has 3 outlets and each device plus the solar gadget gets it's own outlet? Still dangerous?
The problem is that there are many ways to overload a circuit, with this type of product. And without any protection from it, bad things will happen.
For example.
Someone has a lot of power tools in their garage. They can only use one at a time to avoid tripping the breaker. They hear about this product and realize that the front porch receptacle is on the same breaker. They do some thinking about it. And figure out that 4 of these plug in solar products plugged into the front porch, let's them use all of the power tools in the garage, without tripping the breaker.
And voila, problem solved. (Until the house burns down)
For example.
Are we worried about overloading the wiring or the receptacles? The law is written that the device must be UL listed/tested. There must be a way to make it safe to get that UL stamp.
I'm just trying to see how it can work. There was storage device proposed years ago that would plug into the wall. Same concerns came up. As far as I know they are still vaporware.
What if the plug from the solar device blocks the receptacle so nothing else can be plugged into the second outlet in that spot?
The wiring.
The law is written that the device must be UL listed/tested. There must be a way to make it safe.
Not as a plug-in device. There's nothing stopping someone from using multiple units on a single circuit.
Maybe there's a second outlet on the porch. Or they use an extension cord.
Sorta a worthless rule since there is no approved devices. Likely will cause all kind of folks to buy the cheap microinverters (found on Amazon, Ebay, Aliexpress) though and plug them in thinking it is OK. It might even increase the folks that think a suicide cord for their generator is a good idea. All in all just a badly thought out rule change.
It seems to not be any use for the zero export crowd either since the utility company will likely still send someone out to check spurious export and demand for proof of device being an approved one.
It requires a finite amount of time for PV grid push inverter to recognize it has been unplugged.
During which time the male plug prongs will be live.
First kid that gets severely shocked or worse will be the end of that.
If it shuts off in 1/2 cycle because it doesn't see any voltage present, no harm no foul - same as GFCI.
My Sunny Island battery inverter takes 1/2 second. Not sure how fast Sunny Boy GT PV inverter is.
20A house circuits are wire with 12 awg which has 30A ampacity. 15A with 14 awg which has 25A ampacity (at 90 degrees C.)
So one 1200W 10A backfeed would not severely overload it. Two would.
That does not comply with the newer ride-through regulations.
Utilities do not like that and will argue that as population of devices grows it puts the public utility grid at risk of damage.
Strange, that means utilities in Germany must have done something right to allow such devices into their grid.
Ride-through only for moderate voltage or frequency deviation.
Disconnect in 1 second for excessively low voltage, 0.02 second for excessively high voltage, 0.1 second for excessively low or high frequency.
So that could require 0.1 second if unplugged, still several times too long for human safety.
@RCinFLA is correct this seems to have safety hazard.
I see an increase in house fires, in Utah's future.
I read your other response but 1200W is 10A on a 120V outlet. Probably why it limits output to 1200W. On a 15A circuit, it still would be difficult to overload the 14AWG wire before the unit shuts down or trips a breaker in it.
If the circuit was dedicated to solar that would work fine. But no one has outlets like that in their house.
The concern is the overloaded circuit getting 10 amps from solar and 15 amps from the grid.
Uhm, if the circuit is getting 10 amps from solar and 15 from grid... it is getting 5 from grid on balance...
Think it through and there is no case where you can exceed an outlet and circuit capacity... if there is heavy demand it gets used right up
Ok, there is one way.... 10 amps from solar and a shorted wire and 15 amps from grid....so 25amps for a split second and the breaker trips... then the solar cuts out because there is no grid
