I am trying to find out if it's advisable to install a Class-T fuse between the EG4 wallmount 14.3 kWh batteries and the inverter? I believe their internal BMS is supposed to limit current and then there's the breaker/switch as well but is that enough or should I add a T-Class to deal with catastrophic scenarios? I am confused because the T-Class fuses appear to be slow blow which doesn't sound protective for a catastrophic grounding event with LiFePO batteries.
