Does anyone know if the Overkill Solar JBD UART USB module is electrically compatible with the JBD 200a BMS UART port?
I've discovered they use different 4-pin connectors. The Overkill JBD UART USB module has 3 wires (black, red & white) that go to a 4-pin connector that I believe is a 4-pin JST (PH?) connector with 2.5mm spacing. The JBD 200a BMS UART port (which supports both USB & bluetooth) appears to use a 4-pin JST (PA?) connector with 2.0mm spacing. Can anyone confirm whether or not I've identified these connectors correctly? Thx.
