mac on the left coast
- Oct 30, 2021
- 2
Is there a bms that is able to talk with a solark 12k? Is it something to even worry about? Just let the batteries handle their biz alone? Thinking if build out multiple 48v packs then likely if a fault in one, others will keep online to avoid the dont disable a battery while in use clause.. my main concern is the temp switch... Can get cold here in w wash. Seems the little blue cells are the best way to go. After looking at many different pre built options. None of them will say that their bms can tell solark what's going on. Get a lot of "our batteries are compatible", followed by silence if ask about actual communication. Tricky part of build.. which is odd, considering how simple batteries used to be.
Thanks for reading!
Thanks for reading!
