Will it damage the cells if they're in a fixture that doesn't allow them to expand, or is that kind of the point of compression?
I'm thinking of putting rubber on the ends of the battery (4 cell 280ah) if they do need to be able to have some wiggle room, but otherwise I can just enclose them in some thick cutting board and call it a day?
Also, my first battery failed because vibrations from having it in my van caused two of the cells to chafe against each other, so do you think rubber would be a better vibration proofing material between the cells over fr4 fiberglass sheets?
