solararray
- Dec 10, 2020
- 5
Hi all,
Cool forum, I haven't joined a forum in such a long time. This one looked really interesting.
So, I'm working on an off grid backup power supply to my home to keep a few important appliances going fridge/freezer etc.
I have a Goal Zero Yeti Lithium 1400. I want to have a battery bank to increase energy storage. I can buy a 'yeti link' that I can plug into the GZ so I can connect additional batteries. However it is a very expensive at around $400.
Now, the manual for the yeti link states "The Link is a 65 Amp Lead-Acid to Lithium Charge Controller that allows you to chain lead-acid batteries to a Yeti Lithium power station."
Yeti link manual here: https://www.goalzero.com/media/files/yeti-link-expansion-module-user-guide-114-df81.pdf
So I'm thinking; is there a cheaper charge controller I can use instead of the expensive yeti link?
There are two different battery chemistries going on: Lead-acid and Lithium and from what I have read from numerous sites you cannot charge lithium batteries with a lead acid charger due to differences in voltage etc.
Does anyone know of a suitable alternative and cheaper charge controller for this application? Or could you use lithium batteries for the external storage so you do not have the problem with different battery chemistries. Perhaps if you used the same lithium battery that is in the GZ?
I am aware of the Youtube video where the fellow charges his GZ with a battery connected by a 12v auto adapter but in that video he is limited to 60w-120w of input to the GZ.
Here:
The yeti link can recharge the GZ 1400 at a rate of 454-750W from its expansion batteries which is far better and will help prevent the yeti from discharging itself faster than it is getting charged!
Would the theoretical setup be something like
Solar panel>charge controller1>external battery bank>charge controller2(in place of the yeti link)>Goal Zero yeti
There are two charge controllers in that setup and I believe I read somewhere about that not working ---but what if the solar panel, charge controller1, external battery bank were all 24v and charge controller 2 converted the 24v to 12v for the yeti?
So I suppose in summary, is there a suitable alternative to the yeti link? For example a 3rd party charge controller hooked up to external lithium batteries? I've seen some people on the forum have modified their GZ's.
Thanks!
David
Here:
Thanks!
David
