jdege
- Dec 16, 2020
- 183
Consider a boat with batteries you want to charge from shore power.
Different marinas have different current limits. Some provide 20A, some 30A, some 50A, some provide two outlets you can combine.
If you're cruising, rather than day-sailing out of a single marina, what size charger do you use? If you go with a 15A charger you'll be safe, everywhere, but you'll be charging more slowly than you could, when you plug into a shore outlet that could handle more current. If you go with a 24A charger, you'll get faster charge times when plugged into 30A, but you'll be unsafe plugged into 20A.
Do they make chargers that can be current limited? That you can set to charge more slowly, when the shore power connection can't take higher currents?
